Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 3274 Registered: Mar-06 | Do They make FM MODULATORS with a USB playing device? I find USB FM TRANSMITTER's but i dont want the SQ loss from it, so i would rather hard wire it into my antenna rather then broadcasting a new signal myself. Has anyone ever looked for them or found any? http://www.roadmasterusa.com/fmmod_vr3.php This is the FM TRANSMITTER (it transmitts the signal like a radio station would) i need a Modulator (it plugs directly into the antenna) but alot of the stores dont realize they are posting it wrong calling it a Modulator when its a Transmitter...... anyone? i really want to get my USB support onto this stock HU. |
Silver Member Username: Kpa2727Post Number: 268 Registered: May-07 | look up the ipod shuffle the older models they were usb powered only so u might find one there. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 3078 Registered: Jul-06 | I think I know what you're saying. But you would need some device to play the music from the USB drive, and then connect it to an FM modulator with the headphone jack cord. And you're not going to find that since that device would basically be an MP3 player using a USB drive as memory. You could do what you are wanting with a SD card MP3 player though. You would just be using SD cards as memory instead of a USB dive. Is there a problem with that and did I get what you meant there? |
Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 3276 Registered: Mar-06 | What i was hoping to find would be somthing like the FM modulator along with a seperate box that connects to the inputs (this box would have playback support and wire with a usb jack to mount it somwhere) and a remote or IR extender to control it) All i need is USB support. I also have a 2GB sony Pro DUo 2 card... along with a adapter. but either will work, show me a link ![]() |
Gold Member Username: Nd4spd18Southeast PA Post Number: 3083 Registered: Jul-06 | Well it looks like what you would have to do is use an MP3 player connected to the FM modulator. Also you said you didn't want to lose quality...... are you aware that you will lose a tremendous amount of quality from the FM modulator? The SQ loss of the MP3 player would be minimal by comparison. |
Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 3277 Registered: Mar-06 | i already know that, im just saying there would be even more of a loss from a fm transmitter |
