Bronze Member Username: BigharvPost Number: 25 Registered: Jun-07 | Ok, ive been working on my first box for 2 budget 12"s just as kinda practice. I've got my dimensions and everything measured out to make it a 4ft^3 box. Now I've started cutting out my peices and I cant figure out the port part yet. I drew up some designs for the box so tell me if this looks right. <img> The dimensions are 32 long, by 19 deep and 14 high. The speakers are 12" for the perspective. I'm trying to tune it to 35 hz and based off the port dimensions of what I have drawn, the opening is 2x14. I used an online calculator and it said the length should be 10". Does this design look correct? the port looks akward and not very functional this way like it might be too short. I just need to know if this is right so I can feel confident gluing my box together. |
Bronze Member Username: BigharvPost Number: 26 Registered: Jun-07 | |
Bronze Member Username: BigharvPost Number: 27 Registered: Jun-07 | |
Bronze Member Username: BigharvPost Number: 28 Registered: Jun-07 | c'mon now anyone? |
Gold Member Username: Van_manBoston South, MA Post Number: 2616 Registered: Mar-06 | Try this thing and see what it gives you. http://www.subwoofertools.com/forum/ported-box.asp |
Gold Member Username: Van_manBoston South, MA Post Number: 2617 Registered: Mar-06 | Heres another one. http://www.reaudio.com/speaker_box/LPort_Box_Calc.html And lastly, http://www.carstereo.com/help/Articles.cfm?id=31 |
Bronze Member Username: BigharvPost Number: 29 Registered: Jun-07 | Here is my new box design. The box dimensions are 32x18x19 and the port is 4x18 and its 18 inches long. this should be a 32hz tuning. how does that look? |
