Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 796 Registered: Mar-06 | how much power would a hifonics BXi 2006D put out at 1 ohm? it is rated at 2000wrms at 1 ohm but how many real watts does it have? |
Gold Member Username: Logan__tilleI make it rain. Post Number: 8228 Registered: Feb-06 | Im guessing 1700-1800 |
Silver Member Username: YukhuiMyrtle Beach, South Carolina USA Post Number: 470 Registered: Jan-06 | With most hifonics rule of thumb is 70% of what they are rated. |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 797 Registered: Mar-06 | does anyone know where i can get a sundown 1500 for under 450 |
Gold Member Username: 420alldaylongPost Number: 2131 Registered: Sep-06 | Low Hz.com lowhz01@yahoo.com |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 5705 Registered: Feb-06 | the bxi2006d do with good charging that the amps needs will do 1800 rms of clean unclipped power and with stock 12 volt- 13 volt system probably some 1600 watts rms. and for the price the hifonics is a better deal if you dont want strapable amps or really low ohms load since then you will need tons of charging upgrades wait dude find the hifonics bxi2607d is the new one realy cool one is strappable and 2600 rms have underated 0 gauge wire fittings and 8 gauge speaker out put connections and is a really cool amp and it goes around 450 on ebay tottaly worth every penny you should be thinking of that amp. and check some forums they have some threads abotu this amp some example caraudio.com this one can do .5ohms all day really cool amp and im thinking of grabbing a pair |
