OK so my friend gave me these really cheap a long time ago... just now getting to putting it into action... maybe? im not much of an electronics guru and havent the slightest clue if they will even match up due to the ohm'age and wattage and whatnot... little help? will these match? I have two audiobahn AW1006Q 10inch subwoofers specs: * aluminum woofer cone * 2" foam surround * dual 4-ohm voice coils (your amp must be stable down to 2 ohms if wiring in parallel) * frequency response 22-500 Hz * power range 50-900 watts RMS (450 watts per coil) * peak power handling 1,800 watts * sensitivity 95 dB * top-mount depth 5-15/16" * sealed box volume: 0.5-1.15 cubic feet * ported box volume: 1.714 cubic feet * Recommended Q-Logic Box Type: 1 * 1-year warranty
and the audiobahn A2x200hq amp specs: 100 x 2 @4 Ohms 200 x 2 @2 Ohms 300 x 2 @1 Ohms
ya u just got to wire the subs parallel so that they are wired to 1 ohm, and then just bridge the amp. that will be 800 x 1 @ 1 ohms, which will give each sub 400rms.
