Just ordered...
Username: Fearthisskyy
Carrollton, Texas United states
Post Number: 171
IDmax.v3 12" d4
what would be a good amp to go with it? around 800-1000wrms at 2ohms... budget $200-$350 the lower the better.
I was originally planning on the eD nine.1
Username: Ctmike
Ct.
Post Number: 4734
sundown sae1000d. can get it for about $320 shipped.
Post Number: 172
I kind of want something that will put out 1500wrms @ 1 ohm as well, incase in the future I want to purchase another IDmax to pair it up.
Any recommendations will help!
Username: Ctmike
Ct.
Post Number: 4735
ohh, sorry, totally missed that. up your budget and get the sundown 1500 from low-hz then, that'd power a pair nicely.
Username: Skibum12189
Cleveland
Post Number: 782
the nine.1 would be great....is does 1200 at 12 v which means its probably doing nearly 1400-1450 at 14.4 so even if your chargings only at like 13.5 you'll still get 1300 im sure
Post Number: 173
Found a BNIB sundown sae-1000d for $250 good deal, but I heard you can get a refurb eD nine.1 for around that price as well... if I plan on running a one sub set up, should I get the sundown sae-1000d or eD nine.1?
sundown is rated 600wrms @ 2ohm, while eD 9.1 is rated 800wrms @ 2ohms. are the both very underrated?
