Rovin!
Username: Joebruce
15 Inch Wang...
Post Number: 1050
Hey i know you had the MB Quart RAA1000 so i gotta question for ya. Im pretty sure i have it hooked up right but i just wanna make sure. I have one 2ohm dual vc sub and to get a 1ohm load from the amp i just hooked each coil to each of the speaker outpuits on the amp. Is that right? B/c it says the are wired internally to get 1ohm.
