Wiring up fans to your amps.
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 463
Well.. i have 4 12 volt cooling fans and want to keep my amp cool. How do i wire them?
Thanks, Colby
Username: Adddisorder
West palm, Florida
Post Number: 4594
get a 12v 30 amp relay from the auto part store they are like 10$ then you wire 12v and - and the fans to the relay and use the REM as the trigger.
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3129
i always used the REM to power them in general if you pop your radio fuse, add the current the fans pull togethor on top of the current radio fuse and put in the next closest fuse... problem solved.. cheapest way
BTW is it like a pc fan? they dont pull much at all... 4 might be like .6 amps
Username: Johnfiac
Post Number: 3130
1.6*
West palm, Florida
Post Number: 4600
dont do what killa said or you will most likely burn up your HUs REM output. they are designed to only output a very small amperage.
