Box for my sd 2.5
Username: Oglejust
Post Number: 1922
2.5 cubes, 40 hz, 2 4 inch aeros 14inches long, 20 wide x 14 tall x 22 deep, birch baffle
Username: Oglejust
Post Number: 1927
Username: Jblanford
Post Number: 1391
ghey
Username: Oglejust
Post Number: 1929
EVERY1 IM USING THIS THREAD LOL
Username: Jblanford
Post Number: 1397
Don't reply to this useless thread
Username: Oglejust
Post Number: 1931
dont reply to this useless person ^^^
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 8070
Is this necessary?
Username: Oglejust
Post Number: 1941
yup
A pic is worth 1000 posts!!
Post Number: 7402
We need a padded room here on E.
It would always be full.
Username: Th3pwn3r
Post Number:...
Post Number: 3111
That probably won't sound all that great for a daily box.If you're planning on using that for daily you should tune to 32hz.
Username: Oglejust
Post Number: 1945
40 hz ftw
Username: Th3pwn3r
Post Number:...
Post Number: 3112
Don't expect it to be that great sounding at 40hz.
Username: Oglejust
Post Number: 1946
i dont think it will respond as good at 32hz.... an sd 2.5 isnt a low end monster
Post Number: 8075
Yea, They like higher tuned boxes.
Username: Spandmh1
Tunnel hill, Ga AudioQue ... Usa
Post Number: 286
my 2.5 is tuned to 40hz and it gets loud as fook
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 184
dude just tune it too 40. thats what the 2.5s are supposed to have. hit DJ up he will make u a box sketch
Username: Insearchofbass
Post Number: 5324
we might try ours in a higher hz box ours is tuned to 35 hz and slams but I like that box justin
Post Number: 5325
MAtt
"my 2.5 is tuned to 40hz and it gets loud as fook"
how loud is yours did you meter it
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey Audioque...N...
Post Number: 370
I have my box for 2 12 sd2.5 tuned to 40 and they hit...according to DJ you have them tuned to 45 and they will do a good job
Username: Oglejust
Post Number: 1950
im not tuning any louder than 40 hz for daily but i might for an spl box... btw i just got home from buyin wood.... f@ckin 70 bux in wood lol bought 3 piece of mdf
Post Number: 5326
where did people get that the audioque 12 2.5 needs tuned to 40 hz I didnt see that recommended anywhere
Username: Oglejust
Post Number: 1957
email dj and he'll tell u
