Deading..
Username: Chris_t54
Post Number: 149
hey guys im looking to do my trunk and my doors im wondering if i should jus go mainstream with some dynamat for get some ed dead material or is there a really good brand ive prolly never heard of that works good?? lemme know guys! thanks
Username: Chris_t54
Post Number: 151
anyone?
Username: Bernymac
Cambodian
Post Number: 2872
Edead v1se^2, works good. really good. Buy it at the forum price, which is like 1.28 per square ft or so.
Username: Chris_t54
Post Number: 152
sweet so like don't go dynamat then??
Username: Bernymac
Cambodian
Post Number: 2873
hell no. Why do you wanna do that for. And its expensive as fu ck. Do edead, you'll be good to go. A lot of the members here use edead. Go for the V2 and try to get it at the forum discount. You have to be a member of the forum. As for the link to buy it, not sure. Maybe someone else can help you on that.
Username: Chris_t54
Post Number: 154
k thanks berny
Username: Mike11202
DE US
Post Number: 718
I just used eDead v1se^2... it melts and falls off in the heat (i did use a rolller to make sure all was sealed) took me about 14 hours in 1 day to install and it falls off in the heat, it only gets about 90 degrees max around here too
Username: Oglejust
Post Number: 1864
im a cheap mofo... i used peal and seal lol. o and i used some of the liquid edead like the v3 or something
Username: Thumpinwith8s
Formerly known as Wolf...
Post Number: 43
I heard that peal and seal will come off in the heat too. I was thinking about using it until I heard that, and the heat around here can get up into the 100's
Username: Oglejust
Post Number: 1870
acctually it hasnt lifted or pealed at all... i think it helped too
Username: Chris_t54
Post Number: 170
well should i go for the edead 1v2 or the edead 1vs2 the difference is like $.48 and im jus doing my doors and my whole trunk how much sq ft. do you think that would be i have a 97 monte carlo ls coupe
Username: Ctmike
Ct.
Post Number: 4692
i never have had a problem with the edead v1 i have in my car and it's been in for about a year now. just to let you know. order about 200sqft. and don't buy the roller from ed, i got about the same one (roller part was a little smaller but actually worked out better) for $3 at a hardware store, in the section where they sell wallpaper and paint.
Username: Chris_t54
Post Number: 171
200 sq ft. are you serious ha
Username: Tatonka
Post Number: 424
Wolfman, I use peel n seel. Its $12 per 25 ft roll at our local lowes. It doesnt un stick at all during the heat.
Username: Ctmike
Ct.
Post Number: 4693
forgot that it's a coupe, but maybe just a little under 200. about 30-40sqft. a door, the rest for the trunk. believe me, you'll go through alot more than you'd think, especially when you start doubling up areas, which most people do cause as they start sound deadning they start finding little spots that need more.
Username: Bernymac
Cambodian
Post Number: 2886
You don't need 200sqft. I ordered about 100sqft and its alot.... A better question to ask is, where you live, does it get extremely hot? Like 90 degrees +. Then base your decision on that. Raamaat was my second choice, but was to expensive.
Username: •cam•
Post Number: 546
http://www.edesignaudio.com/edv2/advanced_search_result.php?keywords=forum
^forum discount
Username: Chris_t54
Post Number: 173
yea it gets into the 90's occasionally i live in the middle of minnesota
Username: Chris_t54
Post Number: 175
so i should be fine with around 100 sq ft??
