Looking to replace Type R's with something less deafening
Username: Cried
Erie, PA US
Post Number: 114
I have a kx1200.1, and my budget it whatever I get out of my Type R's plus that flared box.
What do you guys think would be my best bet. My ideal setup would be 2 w6's, but I dont have $800 to drop on the subs. I was thinkin possible either 2 12" RE SE's or 1 FI Q or... possible a TREO TSI... idk, I just don't think I'll have hearing by age 20 if i keep these R's. They do have amazing SQ though, might I add...
Username: Jonesp
Post Number: 307
turn them down
Username: Jonesp
Post Number: 308
turn them down, tune them lower, go sealed, use one
Username: Cried
Erie, PA US
Post Number: 115
box included?
Username: Sheriff
Post Number: 482
Nope.
Username: Cried
Erie, PA US
Post Number: 116
$210shipped
Username: Cried
Erie, PA US
Post Number: 117
they are 2 12" if you didnt know ;)
Username: Sheriff
Post Number: 483
Not bad, how long were they used?
Username: Cried
Erie, PA US
Post Number: 118
not long at all. Maybe 2 months roughly with a lot of down time. Very low hours.
Username: Cried
Erie, PA US
Post Number: 119
does anyone know anything about the re mx. Is that more sq or spl? How about re subs in general are they more sq or spl oriented? Same with RD? I know fi q is sq, but I just want to look at all my options.
Username: •cam•
Post Number: 479
fi isn't just sq. rd is both i think.
Username: Loudon
Post Number: 1182
rd classics
Username: 04redmach1
Columbus, GA USA
Post Number: 889
O ya, the classics are ear sex, but gonna be loud too. You may want to check out the RD Studio's or a single Sonance :-) Shoot me an email.
Kevin
lowhz01@yahoo.com
Columbus, GA USA
Post Number: 890
Do you plan on keeping amp??
Kevin
Username: Andrew571
Post Number: 889
ill give u my brand new 18" Q for 290... just like ordering from fi only 20 bucks off!
Username: Cried
Erie, PA US
Post Number: 120
cam, the q is sq. Hmm.. andrizzle, im not sure that it will fit in my car.. I know it wont fit facing the taillights, but will it still sound ok if the sub is up and the port is back (towards the taillights)
No im keeping my amp
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 5360
phoenix gold octane zr ftw....
the zr get as loud as hte type rs but with alot more sq :-)
so its up to you
Username: Cried
Erie, PA US
Post Number: 121
Ok, Im looking for a sub with that DEEP BASS CRAVE! My R's are deafening with a TON of vibrations, and I can't tune them any lower than like 35 Hz..
Username: Cried
Erie, PA US
Post Number: 124
im really thinking about a 15" Q, or an 18" Q and tuning it to like 28Hz. Hmm..
Username: Ctmike
Ct.
Post Number: 4606
why can't you tune them any lower? i had mine tuned lower and liked them just fine for what they were.
Username: Cried
Erie, PA US
Post Number: 125
If i remember right, the manual didnt suggest anything lower than 35Hz. I think the Q would hit lowest at 28Hz.
Username: Ctmike
Ct.
Post Number: 4607
who cares what the manual says. do you think everyone follows what the manuals' say for box sizes?
Username: Cried
Erie, PA US
Post Number: 126
well if the company who makes the sub put that in there for a reason, it's obviously got some meaning.
Username: Cried
Erie, PA US
Post Number: 127
NEW IDEA! 2 12" fi Q's @ 28Hz on my little kx1200.1 temporarily.
Username: Ctmike
Ct.
Post Number: 4609
it's a recommendation, that's about it. what does the manual say about rms? and how much are you giving them? look how many people were giving the q more than the 'rms' before the bp option was available and nothing at all wrong with them. you can tune them lower and like them. had mine lower and they were fine, and heard them tuned to 30hz. and they were fine. can't go by just what the manual says.
Username: Cried
Erie, PA US
Post Number: 128
what would my output be for one dual 1 ohm, and two dual 1 ohm subs?
Username: Ctmike
Ct.
Post Number: 4610
they wire the same as dual 4ohm subs.
Username: Rovin
4 10 Pioneer...
Post Number: 11637
who said u cant tune em under 35hz
in fact i had mine 32hz & u got it all - SQ with loudness
also had mine each in only 1cuft sealed & then amazed me how loud they got yet had nice SQ on it too
i suggest u spend only $0 or so & build urself a sealed box & then decide if u want to change ......
Username: Rovin
4 10 Pioneer...
Post Number: 11638
^^$40 i meant -lol.....
Username: Ctmike
Ct.
Post Number: 4611
exactly what i was saying^^.
Username: Cried
Erie, PA US
Post Number: 130
lol but i think i want to either go with w6's or 12" fi q's =/ thanks though. I want to move on from my type r's and step it up a bit.
Username: Rovin
4 10 Pioneer...
Post Number: 11639
i see - if were me i would try a 15" Q ....
Username: Cried
Erie, PA US
Post Number: 131
1 15w over w 12q's? my trunk isnt the biggest. my current box is 36x16.5x13.5 and thats pushin it. What about those W6's, you dont seem to be givin much love to those powerhouses. It would be perfect for the amp i got too, the kx1200.1.
Rovin, do you think it would be possible to put that 15 Q in a box roughly 36 inches wide 16.5 inches deep and 13 inches tall and tune it to 28 Hz?
Username: Cried
Erie, PA US
Post Number: 132
1 15q over w 12q's? my trunk isnt the biggest. my current box is 36x16.5x13.5 and thats pushin it. What about those W6's, you dont seem to be givin much love to those powerhouses. It would be perfect for the amp i got too, the kx1200.1.
Username: Cried
Erie, PA US
Post Number: 133
1 15q over 2 12q's? my trunk isnt the biggest. my current box is 36x16.5x13.5 and thats pushin it. What about those W6's, you dont seem to be givin much love to those powerhouses. It would be perfect for the amp i got too, the kx1200.1.
Username: Cried
Erie, PA US
Post Number: 134
holy sh!t, I cant type today.
Username: Rovin
4 10 Pioneer...
Post Number: 11646
havent been around any w6 -hear some 13w7 which is SWEET so w6 SQ should be even better if u can afford it - more SQ subs
36x16.5x13.5 = 4.21 b4 any displacement so it should be kinda tight after sub\port displacement but can work
28hz u will more FEEL the bass than HEAR it - i like 32-33hz for nice SQL - u should email owner of FI since its his subs & he will give u the best advice what to do ........
