Can you do this or not
Username: 420alldaylong
Post Number: 1854
Competion Street A,B,C
Single cab trucks
Can you put the box in the seat and put the amp(s) on the sides of the box. And if in Street C can you put the second battery in the passenger side floor board. Thanks
Username: Nd4spd18
Southeast PA
Post Number: 2878
You can't do anything that interferes with "normal use" of the vehicle, or make any modifications to the vehicle. So I would say box on the seat is definitely a no.
And if by "in the floor board" you mean an under vehicle battery box, those are not allowed in Street.
Post Number: 1857
M.S.
So your saying if the person can still drive the truck it's ok. And the battery would be inside on the passenger side floor board.
Username: Nd4spd18
Southeast PA
Post Number: 2880
The way I interpret the rules, no you can't do that. The whole interior has to be in "normal use" condition.
To be absolutely sure, post your question on Termpro in the DB drag rules section. You will get a quick/accurate answer there.
