Wiring 2 dual 4 ohm subs
Username: Sound_quest
Post Number: 24
i have a rockford t5002 can this amp be hook up at 1 ohm
Username: Jblanford
Post Number: 1229
yeah bro, but i don't think that amp is 1 ohm stable
Post Number: 25
well here are the spec on the amp take a look and see if it can be done
View larger and other pictures
Rockford Fosgate T5002
Product ID: t5002 | Product SKU: 7541
Click here to shop for other Rockford Fosgate car audio products.
Product Description:
500 Watt Power Series 2-Channel Amplifier
RMS Power Output
4 ohms: 75 watts x 2 chan.
2 ohms: 150 watts x 2 chan.
1 ohms: 250 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Bridged, 2 ohms: 500 watts x 1 chan.
Tri-way capable (Tri-Way Crossover required)
Variable high-/low-pass filters (40-400 Hz, switchable from 12 to 24 dB/octave)
Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
MOSFET power supply
MEHSA High Performance Thermal Management
TOPAZ circuit for eliminating engine noise.
TRANS-ana circuitry
NOMAD advanced short circuit and power protection
Preamp outputs
Needs 1/0-gauge power and ground leads -- wiring and hardware (not included)
CEA-2006 compliant
Dimensions: 12-3/4" L x 17-15/16" W x 2-11/16" H
1-year Sonic Electronix warranty
Priced Per Pair
Amplifier Specifications:
Amplifier Class N/A
Number of Channels 2
RMS Power (4 ohms) 75 watts x 2 channels
RMS Power (2 ohms) 150 watts x 2 channels
RMS Power (1 ohm) 250 watts x 2 channels
Bridged RMS Power 300 watts x 1 chan. @ 4 ohms / 500 watts x 1 chan @ 2 ohms
Peak Power Output 500 watts
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged 2 ohms
THD at Rated RMS Power <.05%
Speaker Level Inputs No
Amp Preamp Outputs 1 Pair
Built-in Crossover HP/LP
High-Pass Crossover Frequency 40-400 / 400-4000 Hz
Low-Pass Crossover Frequency 40-400 / 400-4000 Hz
Subsonic Filter
Signal-to-Noise Ratio 80 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Punch Bass EQ
Fan Cooled Yes
Fuse Rating 100A
Username: 420alldaylong
Post Number: 1847
Yes 1ohm stereo
Post Number: 1848
Those spec are wrong.
Post Number: 26
ok how would i wire the sub and about how many watts would be going to them
Post Number: 27
what are the real specs then
Post Number: 1849
At what ohm load.
Post Number: 1850
Do you want 1,2,3,4 subs
Post Number: 1853
I can't find the spec right now but when I do I'll post them.
