Speakers play treble then dont...why?
Username: Stevefrench
Post Number: 142
So i just got some kicker ks 6" and hooked them up to my clarion apa210 75W rms per speakers, so they play loud wiht lots of treble for 15-20 seconds then the treble kinda get quieter and the quality is lost, wat could be the problem...no one woud answer in speaker section sorry... Steve
Username: Nd4spd18
Southeast PA
Post Number: 2590
Wait, you just wired two speakers together? They powered by an amp or a HU?
You can't do that, it changes the impedance.....
Post Number: 143
wat u mean i hooked them together, there hooked to the two the amp ( 2 channel )
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1533
sounds like you clipped them and fried the tweets. the ks6 is a coaxial right?
Username: Renegadesrun
Lafayette, IN US
Post Number: 841
Does it have a xover?
Sounds like my CDT's did before i stopped using the POS xovers that came with them. The tweets would attenuate after a short time of play.
Solved by getting a better xover system, because i was not clipping them as was told by CDT. I was told it was the SQ series xovers....top which i replied "super quiet"? Cuz thats just wtf i got! 2 laughs later, we got me into a set without that protection.
Not your issue probably, but it may come up sometime and someone will have their issue explained.
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 2971
how long do u have to turn them down for before you can turn them back up?
Lafayette, IN US
Post Number: 843
Well, id wait 10-15 and they would gradually move back up to full range (50% then 75% then 100%) .....until i overdid it again, over the course of 30 minutes.
Post Number: 145
wat do u mean by cross overs??
