Dilemma
Username: Salmiery
Martinsburg, WV
I have 2 Kicker Comp VR 10" at 2 Ohms. (these are dual coil subs)
I have a Pioneer PRS-X320 2 channel amp. (50w x 2 at 4 ohms.. 200w x 1 [bridged] at 4 ohms as well(not sure how that is but thats straight off of the amp??)
Anyways -- I will be building my box as for the box i had the holes were cut out too big. but the question is - A) how should i wire the subs so as not to blow the amp and still get decent sound.. B) should I build an enclosure with two separate spaces for the subs or can they be all in one? C) should i scrap the amp and wait and save for a bigger and better one?
Please help guys
Username: Salmiery
Martinsburg, WV
^ READ
Username: Th3pwn3r
Post Number:...
Post Number: 2713
If you can sell the amp do it.Get your self a nice D class amp and you'll be better off.The amp you have right now won't really push two of those subs.
Username: Th3pwn3r
Post Number:...
Post Number: 2714
Specifications
* Continuous Power (20Hz-20kHz, 0.04% THD)
o 2 ch: (4 Ohm) 50Wx2
o 2 ch: (2 Ohm) 100Wx2
o 1 ch: (4 Ohm) 200Wx1
* Maximum Power (EIAJ)
o 2 ch: (4 Ohm) 125Wx2
o 1 ch: (4 Ohm) 375Wx1
* Frequency Response: 10Hz - 50kHz (0,-1dB)
* Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
* Signal-to-Noise Ratio: >100dB (IHF-A Weighted, at 1kHz)
* Dimensions: 10-3/8" x 2-1/2" x 11-3/8"
Username: Salmiery
Martinsburg, WV
Should i make it all one enclosure or two separate enclosures
Username: Nd4spd18
Southeast PA
Post Number: 2586
Obviously it would be one enclosure but you have a choice between common chamber and divided chambers. I'm not an enclosure expert so I'll let someone else discuss the pros ans cons of each.......
Username: Bernymac
Cambodian
Post Number: 2773
Depends if he's going ported or not. With ported, I would do common chamber, with sealed, I would do divided chambers.
Username: Rovin
My 1 12 Atom...
Post Number: 11540
from what i tested once with either separate or common chamber (other factors being equal) is :
common chamber is louder but separate had a better Sound quality to it.......
