Memphis Install
Username: Mikeneufeld
Abbotsford, BC Canada
Post Number: 49
I have this for space in my 2004 toyota tacoma extracab... will this accomodate 2 dual 2 mojo 15's. The amp will be a Memphis 4k amp.
Total Space
50" Wide* 14" Depth* 26 " Height
Username: Mgbcs
Maple Grove, Minnesota
Post Number: 1368
Probably...you need to just design a box around that.
Username: Mesodumm
Tri-City, Az Usa
Post Number: 72
NICE!!! Awesome setup!! will sound great!! with right box! Are you wanting sealed or ported? you have plenty of room for those subs, using Memphis specs. 3.50/40/15.5x2x16 per sub Man I would like to hear that when it's done! I have 2 12mojo with mcd1500 and It soulds killer so yours will kick azz!!
Username: Th3pwn3r
Post Number:...
Post Number: 2751
MeSoDumm,you're the first person I've ever heard of saying a MOJO sounds good.
Username: Mmaudioconcepts
Murray, KY
Post Number: 144
i deal with memphis all the time and IMO the MClass and the M1,M2, and M3 models sound better than the mojo. The mojo will have better SPL though.
Username: Mesodumm
Tri-City, Az Usa
Post Number: 73
I wish you guy's could here them! They are very clean! and beat the hell out of you also!! I have always custom built all my boxes, so you can play with it a little adjusting air space, ports size and position or direction, sub angle, deflection, box supports,poly fill, I feel "the box makes the sub!" there are so many variables that can change the bass that is produced In the past I have run Orion, soundstream, jbl, Fosgate, kicker, Sony, MTX and M3124D Memphis. my Favorites were Memphis, soundstream and Orion, the soundstream were used infinant baffle that is a differant bass all together but still sounded great! What subs do you like Rob? thanks and let me know!
Username: Nd4spd18
Southeast PA
Post Number: 2614
^^^^^ Lol at this guy obviously has no idea what sound quality is....... sayin a straight SPL sub sounds good
Username: Mesodumm
Tri-City, Az Usa
Post Number: 79
Arrow Audio 90' to 93' 500 watt pro division, 3 1st place, 2 2nd place, 94' to 96' 1000 watt pro division 1 1st place, 4 2nd place. I did not say it was SQ sub! I said it sound very clean, meaning compared to subs of same class! Which it is a better subwoofer than most of it's equals!
Post Number: 52
And DD sounds good, It's all preference.... My bro's 6 pg xenons imo is nothing to brag about... and my twin bro with his massive audio dmx 15 sounds killer... interesting thanks, any other input.
