Gain
Username: Jesse59672
OK
Post Number: 337
okay i set my gain today. i unplugged sub from amp. turned all settings to 0 and flat eq. gain and bass boost off
i burned a cd with a 50hz tone and played it with a dmm on one of the amp's channels.
anyways with the gain turned up all the way i couldn't get the 35.8 volts i was looking for (320 @ 4ohm) it only got up to 28 or so
the only way i got it to go 35.8 was with gain about halfway up and bass boost up. whats up with this?
OK
Post Number: 339
i'm guessing my amp is severely underrated or something. maybe rated at like 16volts lol
Username: Bernymac
Cambodian
Post Number: 2737
measure your preout voltage on your rca's.
OK
Post Number: 340
5v
Username: Slimdog53185
Bowling Green, Kentucky U.S.
I had the same problem. I still can't figure out where it measure preamp rca voltage though. How did you measure that 5v or did you just go by what the manufacturer says?
I just had to settle for what I thought sounded good and still gave me a high voltage output. I'm still getting about half what I should. I do think that maybe just overrating though. I can't even get the right voltage with bass boost all the way up.
What kind of amp do you have?
Username: Bernymac
Cambodian
Post Number: 2743
Measure your preout voltage. If you did and it says 5V, then I truly don't know what your problem is. You should of reached that 38V reading fast. Make sure your measuring it in AC as well.
Username: Nd4spd18
Southeast PA
Post Number: 2472
If the HU has loudness, is it off?
If it has a sub level adjustment, is it all the way up?
Is the LPF on the amp set at about 80 hz or above?
