I need a box!
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 103
so i need a box for 2 12" kicker comp vr's. will it sound louder if it is ported? anyway i need it to fit in the trunk of a 1998 ford escort 98. dont want any carpet. if anyone can make that would be chill
Username: Ctmike
Ct.
Post Number: 4250
yes it'll be louder ported. wait till logan gets on, he'll build you a box cheap. but if your budget is a little higher you could check out these places:
www.fishercustoms.com
www.woodlawncabinetry.com
www.spkrman.com
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 463
I have a dual 12" Ported box tuned to 33Hz 4cuft. 36"x14.5"x23" if you are interested. It is not carpeted.
Vista, Ca Usa
Post Number: 104
but will it fit in the trunk of my car?
Username: Bjfish11
Garden Plain, KS USA
Post Number: 49
Thanks for the props Mike.
You can email me at bj@fishercustoms.com if you have any questions. If you can read a tape measure, we will be able to work something out that will fit.
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 7202
Yes, thank you mike. I will sell you this box for $100 shipped.
Post Number: 464
I gave you the dimensions, now you tell me.
