Which batt?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1190
When i upgrade my alt and big 3 i wanna get a new batt for under the hood. Which one should i get?
http://www.shipsound.com/product_info.php?products_id=100678
or
http://www.shipsound.com/product_info.php?products_id=100677
Username: Mwyant19
Arlington, Texas Usa
Post Number: 90
yellow top is for sound, red top is for offroad vehicles. but either is better than stock
Username: 420alldaylong
Post Number: 1669
http://www.shipsound.com/product_info.php?products_id=100681
Username: Mwyant19
Post Number: 93
yup
Username: Jode
Post Number: 19
See if you can get a NORTHSTAR NSB 90 they come as a FT ie front terminal or a normal type battery. they are way better then the Optima.
Laterz Brian
Username: Snarl2004
Post Number: 1192
i need the screw in posts on the front of the batt cuz i got a GM car. Is the kinetic rly that much better then the optimas? Also i dont need starting power or anything like that. This upgrade is for audio in mind.
Username: Snarl2004
Post Number: 1193
BUMP damit
so which would be the back
Red top
Yellow top
Northstar
also anyknow where i can get one pretty cheap
Username: Snarl2004
Post Number: 1194
best not back sryy
Username: Waterboy2289
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 367
I would get the yellow top because you need the side terminals and it would probably give you the best factory replacement fit.
Kinetik is better than optima, but there are also better batteries then kinetik.
Username: Snarl2004
Post Number: 1196
ya rly dont need the best i just wanna have enough. Im running 1000rms and im getting a 220amp alt. I just wanna make sure i do this right the first time.
And i was thinking about getting the yellow top i was just windering what other ppl thought.
Username: Jode
Post Number: 21
Sorry but i would definatley go with the northstar. the cold cranking amps are crazy on this bat.
Username: Joebruce
15 Inch Wang...
Post Number: 796
Snarl when you do your big 3 and get your new bat take some pics so ill no exactly how to do it. We have the same truck
