Pioneer premier TS-W3004SPL (read rovin!)
Username: Jesse59672
OK
Post Number: 280
i need some info on this sub. it isn't listed on pioneer's website
ie the xmax, driver displacement anything else you may have.
and if anyone has or has had this sub what did ya tune the box to. how many cuft per sub?
Username: Turnmat
Post Number: 173
xmax: 11.2 mm
displacement:.084
you have to look under the older subs to find the info and than you need to look at the manual
OK
Post Number: 281
so its really that low? i got .43 inches or 10.92mm from another forum and wasn't sure if it was right or not
Username: Turnmat
Post Number: 176
yea its that low...
here is the link i am not sure if it will work though
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/217888139TRD126 3-A_UC.pdf
Username: Rovin
My 1 12 Atom...
Post Number: 11446
i had mine in a few boxes but it seemed to like 2.75cuft-3cuft 33-34hz - i even heard some ppl put it in up to a 4cuft box but i wont advise u to do that
evrey1 seems to think its a spl sub when in fact after its fully broken in sounds quite musical & u get the looows real good too - in fact after only 1 wk of break in it actually shook the rear hatch lock off in my ride !
u can use of the ol basic rule of @ least 12sq"\cuft to give some nice SQL bass ....
OK
Post Number: 283
oh good find. i couldnt find my owners manual
OK
Post Number: 285
http://www.subwoofertools.com/forum/ported-box.asp?Ew=38.5&Eh=12&Dia=6&Xmax=11.2 &Vd=.084&NumW=1&Vb=3.1&Fb=32&Qts=&Vas=&Fs=&CE=0
heres my box i'm planning.. tuned @ 32hz
OK
Post Number: 286
BUMP
OK
Post Number: 287
stupid @$$ forum wont bump lol.
Username: Rovin
My 1 12 Atom...
Post Number: 11447
i still have plans from what i used & i think its this http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15.5&Dia=6&Xmax=10.9 &Vd=.084&NumW=1&Vb=3&Fb=33&Qts=&Vas=&Fs=&CE=0
OK
Post Number: 293
nearly the same box, yours is just fatter mine is skinnier
ill probably make it on wednesday-thursday so ill post pics after i'm done
Username: Paogr
AthensGreece
Post Number: 127
Hey jesse in your plan you have put only 12" for height. I think you have to put a little bigger number...
Username: Rovin
My 1 12 Atom...
Post Number: 11450
trick i used Jesse was to design mine in such a way that u get the port with the least "L" shape bend (only 1\2" in mine) leading to easier air flow & least resistance ....
