Gold Member Username: OlegSanta Monica, CA USA Post Number: 1112 Registered: Nov-04 | I was looking at some DMMs at Fry's and RadioShack today and didn't understand what "8-range" meant and how that compares to 18 or 48 range or something like that. Can anyone clarify this for me? Also, what features is this thing supposed to have? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1970 Registered: Jul-06 | You have to set the range on the DMM when you measure something, 2 volt for 0-2 volts, 20 volt for 2-20 volts, 200 volt for 20-200 volts, etc. If you get a meter with auto-ranging you don't have to do that. |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1118 Registered: Nov-04 | Ok, I did see one with that sh!t! Are all DMMs able to measure low resistances or can some only measure higher ones? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1972 Registered: Jul-06 | All cheap meters I have seen are able to measure low enough resistance for any car audio use. |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1120 Registered: Nov-04 | Cool. I'm getting one 2morrow. Thx M.S. Dude, what's your name?? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1976 Registered: Jul-06 | No problem. Matt ![]() |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 12010 Registered: Dec-03 | for audio use, just make sure the meter has the ability to read "true RMS" or AC voltage. |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1126 Registered: Nov-04 | Gotcha, will look for that too. And Mr. Glass, what is your name? Or do you not reveal it? |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1132 Registered: Nov-04 | Here's radio shack selection: http://www.radioshack.com/family/index.jsp?categoryId=2032305&cp=2032058.2032235 and fry's selection: http://shop1.outpost.com/search;jsessionid=UqFRWHzd8Dsk35aRmitOVw**.node2?query_string=multi+meter&sort=price&o rder=desc&cat=&pType=&from=0&to=24&order_by=p04d any particular one you guys can recommend from the list? the cheaper, the better. |
Gold Member Username: CarguyPost Number: 6177 Registered: Nov-04 | For your budget, get the first one on the Radio Shack list, $89. |
Silver Member Username: Mash4kashLafayette, LA Post Number: 287 Registered: Feb-06 | when setting the gain what setting do you put the dmm on? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2154 Registered: Jul-06 | AC volts. The symbol looks like this: ~ If the meter is not auto-ranging, you set it to the next highest number from the value you will be measuring. For example if 40 volts is the value you're using to set the gain, and your meter has 2, 20, and 200 volts AC ranges, you would set it to 200. |
