also wat do you think woudl we the best type of box for these subs so i can get alotttttt of bass and someowhat decent sound quality somebody told me seiled but i have no clue?
any amp that'll do about 1500-1800wrms at 2ohm would work fine. do you have a budget? personally i'd pick up that kicker zx1500.1. but do you have a budget? and for box, i'd definately port them, about 36hz tuning should be good.
also you may need to think about upgrading your charging system if you haven't done so already. do you happen to know the size of the alt. in your car?
umm i kinda want the best bang for my buck someone told me that hifonics amps are good for the price? also woudl i get a 2 channel amp if i have 2 subs? and im not sure what size my alternator is but im sure ill have to upgrade my charging system i have a 92chavaleir if that tells you anythnig
