Solo x 12 or btl 15
Username: Fx_ryen_04
Detroit, Mi USA
for the price i keep hearing their the ones to buy. or if u know any other sub that will hit harder then the two i'm looking to spend no more than 800 on a sub and 1000 on an amp
Username: Nd4spd18
Southeast PA
Post Number: 1938
wow thats a nice budget....
DD 9515 <--- the sub you should get
DD Z1 <--- the amp you should get
Username: Th3pwn3r
Post Number:...
Post Number: 2258
IMO DD is a sub company and not an amp company.A lot of guys run the Z series amps though but I think there's better for the money out there.Ryen try to keep the similar threads that you make to a minimum.
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 4693
the z2 its a overated amp on stock electricals but push the 18 volt barrier and wil push some nice numbers.... the z1 well dd have ltos of problems the amp was runnign fine at 1 ohm but sometimes blew at 2 ohms... so dd its coming up with a z1a thats supposed to be the fixed version btu still nobody knows... so if u wanna try it out and let us know....
and finally yes dd amps are some overpriced and u can get better for the money
