Gold Member Username: Th3pwn3rPost Number:... Post Number: 2174 Registered: Jul-06 | Here's a nice little bunch of connectors to use. http://www.posi-lock.com/index.html I know I should have posted in the proper area but nobody really looks over there anywhere.These things are pretty sweet BTW,I've used them for quite some time. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12304 Registered: Oct-05 | those are pretty cool man. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2180 Registered: Jul-06 | Yea man,I love them when I'm installing HUs.So much faster than crimping and they hold tight,I've tried to pull them off and they don't budge or slip at all. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12306 Registered: Oct-05 | yeah ima re-install my hu and i am going to used those. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2182 Registered: Jul-06 | Nice.Another good thing is you don't have to cut your wire when you want to remove something as opposed to crimp on terminals.When you remove the crimp on kind you usually have to cut them off if you can't pull them off so you end up losing wire length,which is not good if you're cutting wire on your HUs harness. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1818 Registered: Jul-06 | I'll keep doing it the right way.... crimp and solder. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2196 Registered: Jul-06 | ^Lol.This works just as good and is faster.Funny how I don't even see SHOPS crimp and solder HU harnesses on...hmm. |
