Decisions...decisions...
Username: Tatonka
Post Number: 219
I have a little over $400 atm and im getting about $100 per week. I cant decide what order to buy some things in. This is what I need: new tires and rims (possibly just tires), new alternator, and a car alarm.
Anyone got any suggestions on what order to buy these in? I really can't decide on this debate myself lol.
Username: Riskyb
Post Number: 608
alternator tires car alarm.... no rims unless your riding on doughnuts or you already have a nice vehicle... I hate when someone puts 20''s on a dang ford escort.
Username: Ctmike
Ct.
Post Number: 4104
if you definately need tires that'd be the first thing i'd get. then ho alt. then alarm.
Username: Nd4spd18
Southeast PA
Post Number: 1846
1 Tires (becomes a saftey issue if they're really worn)
2 Alternator (it's gonna be an HO right? )
3 Alarm
Username: Gh0st_31
FL USA
Post Number: 422
rims, tires, alt, alarm
Username: Stnorris
RE SX 15, IA US
Post Number: 2148
1 - rotate ur tires, or if they are all bad replace them.
2 - ho alt
3- alarm
4- rims
dont buy new tires if ur gunna get rims too....new tires that fit ur stock rims aint gunna fit the new rims
Username: Tatonka
Post Number: 220
Tires right now have about 60k miles on them. Also I want something different than hubcabs. The car has several engine modifications and underglow lights, and hubs just completely ruin the effect lol. And yes, I need an H/O alternator. The car alarm can come last since I'm only going to need it next year for school.
I really do not have a big voltage drop. Only at night on idle with the volume up the voltage goes to 11.6 on bass lines. Can any1 reccomend me a alternator? I don't really know what size I need. I got an oldsmobile Alero 2000
Username: Nd4spd18
Southeast PA
Post Number: 1849
Here ya go:
http://cgi.ebay.com/200amp-Amputator-Series-Alternator-Chevy-GMC-Pontiac_W0QQite mZ5758166242QQihZ008QQcategoryZ14932QQcmdZViewItem
Username: Tatonka
Post Number: 221
Thanks M.S. Will 120amps at idle be able to hold my 2 amps? Im running a Hifonics BXI 1206D and a Profile 80wrms x 4 for the cab speakers.
Also I thought a tires/rims combo would be cheaper than buying tires, then rims later.
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 464
lol i will go alarma, alt, then rims
Username: Nd4spd18
Southeast PA
Post Number: 1852
I think it will be ok, but either way it will have to be, since I don't think you will find an alt with more anywhere else.
Username: Jesse59672
OK
Post Number: 229
tires first dumbasses then alarm and then an alty
