2 RCA ouputs on head unit...4 RCA inputs on amp....?????
Username: 66conv200
Hi Gang...first post here.
I have a Jensen stereo that has two RCA outputs
1. Left channel
2. Right channel
The Jensen amp I want to use has 4 RCA inputs as follows:
L R
rear rear
front front
Dumb question but, how do you recommend I wire this for a 4 speaker system (2 front 2 rear)?? Is that what bridging is?
Jensen CR225X, Jensen 600 wat A600XLH
4 Pioneer 160 6.6" speakers
Thanks,
Steve-O
http://www.sounddomain.com/id/66conv200
its_pork12
get an RCA splitter so all inputs can be used, but not all amps need this so look in your manual
Username: 66conv200
Got it used and don't have the manual, thus the question.
Thanks for idea of a splitter.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2867
your best bet is to use an electronic crossover like the coustic XM-3e
