The better sub?
Username: Bholt30
Union, Kentucky United States
Post Number: 7
I have been getting a bunch of different opinions on what subs i should buy so here is what i have been looking at. They would be run off of two SAZ-1500D. My box would come from car audio box.
two JL w6v2 13
two FI Q 15
two brahma 15
two RD alpha 15
Which should i buy?!?}
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 4334
u care more of sq the fi q
or spl the rd alpha....
Username: James1115
Use a simple...
Post Number: 9823
where would you get brahma'a? the JL's arnt even in the same league as the Q's and brahma's. I would go with the Q or if you can get old brahma's mark II's I would get them.
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 1792
you would fry the w6s if you ran 1500 watts to eac of them... that being said... you have a lot of different woofers there... I'd say go brahma
Username: Bholt30
Post Number: 8
I heard alot about the Rd alpha how do they compare to brahma?
Username: Kyle_lowe
Post Number: 242
get crystal comps
Username: 420alldaylong
Post Number: 1261
2 15" Fi BL dual 2ohm
Username: Solobaric4life
Seminole, Al United states
Post Number: 506
^^^^x2
Username: Bholt30
Post Number: 9
would two 15 Q's in a sealed box hit around 140 db?
Username: James1115
Use a simple...
Post Number: 9834
in the propper enclosure with the right power, in the right install yes you would get 140's out of them.
Username: Bholt30
Post Number: 10
how many db could 2 saz-1500D with 2 15" Q's running 2ohm hit in a sealed box in the back of a blazer? what about ported?
Username: Oleg
Santa Monica, CA USA
Post Number: 714
Brahma's still a good sub! Get it!
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 125
Fi Q, too many issues with Adire lately.
And there is no way to predict the db#.
Username: Bholt30
Post Number: 22
i am going to go with 2 DD3515's in a ported box.
Username: Nd4spd18
Southeast PA
Post Number: 1225
right decision
Username: Trey4sports
Post Number: 865
nice decision DD is a great brand, if not the best in car audio
