To all the box builders!!
Username: Liqdfire3
Lee high acres, Florida
Post Number: 157
ok i am looking to have a box built. but i will let you know already that the box seems challenging. it will be a housing for 2 DD 1508's. i want the box ether carpeted or texture painted. also the port is in a kind of weird place so hopefully the drawings help out alot.Upload
Username: Liqdfire3
Post Number: 158
or if who ever wants to build this box for a reasonable price, they can suggest different ways to port it. maybe with round flared ports?
Username: Southernrebel
Post Number: 4766
Try firing the port into the passenger side wall...single cabs like that.
Username: Sinful_systems70
Post Number: 538
I agree but put it as close to the back of the cab as possible and put it straight up and down. Would you want the entire box carpeted or just what you will see? That makes a difference in price, since the extra paint, carpet, and labor will cost more to do the back & bottom of the box. Do you have a measurement for the port size and depth that you would like. Spacific tuning? Color of carpet/paint? Spacific date needed by? Where it will have to be shipped, basic state or zip to get shipping quote. What thickness of wood(MDF) would you like? Any Fiberglass? All the answers to these questions (and more) will help your transaction work smoother. I might but I am pretty hard pressed for time so you might want to try Logan because he builds them. I think his "company name" is "Immortal Box Building". There are others and I am sure someone else will come to help you. If not I will see If I can work that in but I am sure there are others who can help. Hope that helps some. Great Choice on subs as well. NICE!!!!!!!!!!!!! DD = "Good Sh!t"
Username: Liqdfire3
Post Number: 159
Sinful Systems inc.
1)Q: Would you want the entire box carpeted or just what you will see?
A: Just the parts that can be seen. front mostly
2)Q: Do you have a measurement for the port size and depth that you would like. Spacific tuning?
A: Yes 35Hz. Either slot or flared ports. I can find out the length needed for both.
3)Q: Color of carpet/paint?
A: Black
4)Q: Spacific date needed by?
A: None. Just at a reasonable build time.
5)Q: Where it will have to be shipped, basic state or zip to get shipping quote.
A: Lehigh Acres, Fl. 33971
6)Q: What thickness of wood(MDF) would you like? Any Fiberglass?
A: 3/4" & no fiberglass
i think that just about answers all the questions. the dimensions given on the pictures above are outside dimensions. those are max deminsions.
Username: Matt12490
California USA
Post Number: 2106
Logan won't touch this one..
Username: Liqdfire3
Post Number: 160
why not?
