Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 232 Registered: Jan-07 | i want buy that amp to power 1 fi Q (or maybe 1 Bl) but it is on backorder... do you guys know when is going to be available or something... thanks |
Gold Member Username: 420alldaylongPost Number: 1263 Registered: Sep-06 | Not sure on that NINe.1 but check these out. http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3942 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4676 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5469 |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 409 Registered: Nov-05 | ed nine is a better amp then all the ones joey mentioned by far it can put out around 1450 easy. its rated at 12.5V |
Gold Member Username: 420alldaylongPost Number: 1268 Registered: Sep-06 | Around 1450 then boom I've only seen and heard bad thing about ED NINe.1 |
Silver Member Username: OlegSanta Monica, CA USA Post Number: 716 Registered: Nov-04 | Better by far? Don't think so. Those DEI and Orion are solid...no joke about it. |
Silver Member Username: ImalikSD2.5, New Jersey Ocean Post Number: 198 Registered: May-06 | Joey what bad things have you heard about the 9.1 |
Gold Member Username: 420alldaylongPost Number: 1277 Registered: Sep-06 | Mostly heating |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 235 Registered: Jan-07 | thanks!!, then i may go with orion i kinda liked the idea of having a warranty for 5 years |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 413 Registered: Nov-05 | any of those will power ur sub nnicely im just sayin i would get the ed nine over any of these new orion amp |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 236 Registered: Jan-07 | lol ... so mixed reviews ... so i think i will go with a budget one for now then... maybe a hifonics instead of the eD... or maybe a jbl... well thanks anyway |
Silver Member Username: OlegSanta Monica, CA USA Post Number: 718 Registered: Nov-04 | most JBLs are 2ohm stable, hifonics are overrated. Orion is really really nice...talking from experience. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4337 Registered: Dec-05 | kicker kx 1200.1, memphis prd 1000.1, orion 1200d... many amps bro. |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1650 Registered: Jul-05 | the orions i have used/seen heat up much faster than NINe.1s. i own 4 NINe.1s and have never had a heating problem...dont really know where you guys got that one. another great amp too look for on ebay is a crossfire 1000d, i love that amp. the kicker kx 1200.1 that juliob said is another good call. |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 239 Registered: Jan-07 | does anyone know how this amp is rated? (under, fairly or overrated?) Memphis 16-PRD1000.1 |
Gold Member Username: CtmikeCt. Post Number: 3727 Registered: Feb-06 | that's memphis' lower line. still good and just slightly underrated from the one's i've seen. |
Silver Member Username: ImalikSD2.5, New Jersey Ocean Post Number: 200 Registered: May-06 | Hifonics are great budget amps, they do close to the rated power and they are 1 ohm stable...I have a BXI 1206D pushing 2 12 AQ 2.5 nice boom. |
Silver Member Username: MmaudioconceptsMurray, KY Post Number: 118 Registered: Jan-07 | are those powerbass amps any good |
