Silver Member Username: Smoke05
Tucson,
Arizona
U.S.
Post Number: 231 Registered: Jan-07
Posted on well wich one you guys recomend... i know there is a web page ariund from a guy that test them all do you knoow it? well thanks |
Silver Member Username: Sheriff
Post Number: 276 Registered: Jan-07
Posted on They will both most likely work well for you. I doubt that there is a huge difference. |
Gold Member Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1267 Registered: Aug-06
Posted on yeah, both of those are great products... if peal and seal works, those will...  |
Gold Member Username: Ctmike
Ct.
Post Number: 3726 Registered: Feb-06
Posted on edead. works just as good and for the price of dynamat you can do two layers of edead. |
