JENSEN PROBLEM ALSO!!
Username: Miles_hood
Tyler, Texas US
Post Number: 158
hey guys got this jensen 9311 now.. my player wont eject cd's so i opened it up to check it out.. now when i put it back together all it does when i press the power button is beep a few times and then nothing what do i do...is it time to trash or worht fixing..
Username: Mwyant19
Arlington, Texas Usa
Post Number: 27
lol i would try returning it if you still can. trade it out just dont tell them you opened it.
Username: Mwyant19
Post Number: 28
you could also : buy a new one, put the busted one in the box and return it. we call this the switcheroo. ive done it with an original xbox, an xbox360 and tons of other stuff that was past warranty. only way it doesnt work is if they check serial numbers on the actual unit. but then you can still return the legit new one and get back to where you started
