Audioque Users!!
Username: Joebruce
U.S.A.
Post Number: 476
What is the displacement and xmax of a 15" HD3? I need it for the box building program at www.subwoofertools.com What are some other free box building programs?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 658
use this to decide wut to make the box like.
http://www.ddaudio.com/dd/caraudio/enclosureInfo/boxSize_hiEff.asp
audioque and dd are made in the same shop and the owner of audioque is the owner of dd's son.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4023
i believe the disp is like .25cuft and as for the xmax it doesnt matter. just keep changing it until you have 16sqin per cuft. (stay around 3.75-4.25 cuft net)
Username: Snarl2004
Post Number: 659
also they dont tell you the xmax and mim not sure wut the displacment is but on dd's site they add in the vent and sub displacment and just tell you how big to make it
Username: Joebruce
U.S.A.
Post Number: 480
Would this work? It was for a BL but i need the box to be at most 45(L)x24(T)x12(D) cuz i have an x-cab s10
http://www.subwoofertools.com/forum/ported-box.asp?Ew=45&Eh=24&Dia=9&Xmax=21&Vd= 0.18&NumW=1&Vb=4.5&Fb=38&Qts=&Vas=&Fs=&CE=0
Username: Snarl2004
Post Number: 661
just one sub?
Username: Joebruce
U.S.A.
Post Number: 481
Yup a 15"
Username: Snarl2004
Post Number: 662
wut power u giving it?
Username: Snarl2004
Post Number: 663
alright heres wut u should do:
sub facing forward and vent facing up
3.5 total ft^3
outside dimensions=12(D)x24(T)x27(L)
inside dimensions=10.5(D)x22.5(T)x25.5(L)
for the port=10.5(D)x5.5(L) tunes to 40hz...has 56 sq inches of port
^^^^^make the port go down into the box 16 inches.
u might have to change these a little depending on how many rms ur giving it
Username: Joebruce
U.S.A.
Post Number: 482
Well i dont have the sub yet but i wanna get it when i get my tax money. But when i get it i will be running a mb quart raa1000 to it at 1ohm getting 1000w rms untill i can afford a bigger amp. I was thinking either a nine.1,massive 1500.1,cadence daytona 1600.1,or when the time comes if i can afford it a sundown 1500. So what do you think of that box? Its 4.5 q ft. What is a good tuning freq.?
Username: Joebruce
U.S.A.
Post Number: 483
Why only 3.5 ft^3? That seems kinda small for a 15 i was thinking at least 4^ ft^3
Username: Snarl2004
Post Number: 664
did you look at the dd page i listed above?
this sub will work from 3-5ft^3
3.5 will be plenty if ur only putting 1000 rms to it. if ur gunna put 1500 to it in the future then ide make it about 4 and i would go much bigger then that unless ur putting 2000+ to it. i have 2 12" SD2.5's in a 5 ft^3 box tuned at 42 and they sound great.
if ur gunna get the new amp then ide make a 4ft^3 box and then u would need 64sq inches of port.
u could go up to 4.25 or 4.5 but i think thats a waste
Username: Djl
Post Number: 39
I will be the first to tell you that DD/AQ subs do not lend themselves to box modeling programs. That's why we don't publish all of the ts specs. We design our subs around the box sizes and port tuning we recommend.
Our subs like 16 sq" of port opening per net cubic foot of box volume and 16" of port length for 40Hz tuning. Each model series of the same basket size will work in the same box. 10" subs like 1.2-1.5 cubes. 12" subs like 1.7-2.5 cubes. 15" subs like 3-4.5 cubes.
Username: Jblanford
Post Number: 586
dj how would my hd3 15" do in a box at 4.2 cuft net at 40hz with 4 4" aero's ?
Username: Djl
Post Number: 40
You would be a little shy on port area but should work fine. The aero's seem to work on a little less port opening area. If you could make the aero's external and adjustable it's easy to change the tuning.
Username: Jblanford
Post Number: 588
yeah i should have added they were external
Username: Snarl2004
Post Number: 665
DJ,
my friend is thinking about getting 2 15" SD2.5's and he will be giving them about 800rms for daily driving. will they be able to handle it. also how much power for daily driving can they handle. thanks
Username: Jblanford
Post Number: 591
btw sorry for threadjacking
Username: Djl
Post Number: 42
The should be fine if he doesn't clip the signal. I don't like to give a figure on how much power you can give a sub because that depends on the application and skill of the enduser. We are conserative in our ratings but have no control over the skills of the enduser.
Username: Snarl2004
Post Number: 666
alright thanks.
Username: Djl
Post Number: 43
I do know how to spell conserVative and they. Sorry about that.
Username: Snarl2004
Post Number: 667
lol spelling rly doesnt matter :-)
