If you don't draw enough current for amp specs, will it hurt the amp?
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 646
Could i hook up my orion d5000 without a ho alt.? If I just wanted to run one sub, would that be ok? I know it won't push it's potential, but will it hurt the amp?
Bassrace 147.2 dbHttp://com4....
Post Number: 11205
depends. if you voltage drops it can hurt it. i wouldn't recomend it.
but since you are only running one sub, you can run it at higher ohm so the amp doesn't need to produce the full 2500wrms.
Username: Skies
Courtenay, British Colu... Canada
Post Number: 410
^^ He got it.
Highly recommend wiring it in series for the higher load until you can get a HO alt and really unleash the beast.
Username: B101
Everyone is ... USA
Post Number: 4213
those amps like about 200amps each at optimal ohm load for max power... at a higher ohm load, you should be ok, with only a 100-150 amp pull of current.
yes, to answer your questions lack of current, will make internal parts of the amps, to over heat. Example ics, chips, transistors, etc... all these can heat up solder points in the board, and stuff can eventually shake loose. if you feel the chips on the board itself, with proper current, you will still see how hot they get under proper operation!
