Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 297 Registered: Aug-06 | so when ure power is al hooked up and everything an dthere is no power comeing from the amp light and no spark when u hook up the amp even with the batery on is ure amp fried or wut? |
Gold Member Username: Logan__tilleImortal Box Building, Email us wit... Post Number: 6357 Registered: Feb-06 | does it push the subs? |
Bronze Member Username: QuirkySA, Texas Post Number: 53 Registered: Feb-07 | try oppening it up n checking, ull know if it is fried. most likely you just forgot to do something. could just be that a fuse is blown on ur amp.. |
Gold Member Username: James1115Use a simple... Post Number: 9427 Registered: Dec-04 | no spark? what is it an engine? there is not supposed to be sparks with electronics. |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 298 Registered: Aug-06 | ok no it does not push the subs it dont even turn on. it did b4 ut now i go to hook it back up and nothing its weird cuz liek when i took the fuse out i would see the power light come on but only for about 5 sec then it would go back to nothing, and dim away, then when i would put teh fuses back in it would do nothing at all, and yes james i remember when i used to have my first system when i hook up the power without unhooking the ground it would spark the amp, and i tryed leaving the battery connected and nope no spark at all. so if you guys could tell me what it could be that would be helpfull the amp is only about 3 months old and i have no idea how it could be fried already, its a kenwood 9102d but i know it isnt a best brand guys |
Silver Member Username: Nd4spd18Southeast PA Post Number: 773 Registered: Jul-06 | I will bet it's blown. And I'll bet it's the power supply, kenwood amps are infamous for that. |
Gold Member Username: JohnfiacIL Afghanistan,... Post Number: 1770 Registered: Mar-06 | ive never had a problem with my kenwood ![]() |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 299 Registered: Aug-06 | ok il try that killa but im sure it aint gonna do anyhting lol well thanx guys ill let u know what it does when i do what killa said |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 303 Registered: Aug-06 | ok yes i tried that and nothing so it has to be blown my guess is unlessu guys can think of sumthin else but i tried another crappy lanzar amp my neighbor had laying around and that works so i guess it is blown i am gonna try and send it to kenwood and get a new one otherwise im out 327 dollars again yes i got ripped |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 306 Registered: Aug-06 | bump |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 308 Registered: Aug-06 | ahh well my dad called bestbuy and they said if i have teh serial number code on it they would fix it and , i was like sweet even without a receipt and he said yea cuz he told them i lost it , but if they see that there is liek a power wire shocking part like on the metal by the terminal will they still fix it or will they say wel u abused this amp? that was b4 i knew not to unhook the power and ground of the battery though.. but is it true they fix it or do they just give me a new one cuz my friend got alpine type r subs and blew them and they just gave him new ones but idk if he had a special waranty on them or not so do u guys know? |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 607 Registered: Dec-06 | i had a kenwood that when u turned the car on the power light would turn on and then turn off after about a second. it turns out the amp was fine it was jsut going into protection mode. it turned out that i didnt scrape all the paint off where i grounded it so the amp wouldnt turn on and would always go into protection mode. also check all ur connections make sure theres no shorts. |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 608 Registered: Dec-06 | b-u-m-p- |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 313 Registered: Aug-06 | yea but that cant be my problem cuz i have had that amp hoked up in my car for about 2 1/2 minths now then i put it in my friends car for about 2 weeks then i go to hook it back up and nothing it wouldnt work, but my friend only played it for about 1 hour of those days he had it cuz his car broke down in my driveway and then sat.. so no snarl2004 i dont htink that smy problem and all my wiring was already installed i never took it out , and yes when i first put it back in it blew the power wire fuse then i changed it and nothing no power but when i was hooking it up i never got a power lite just blew teh fuse so i have no idea what it is |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 613 Registered: Dec-06 | take off the cover to the amp. if somethings fired you will be able to see it. if you can take some pics and post them im sure some ppl here can point out some things for ya. also if its fried u will prob be able to smell it |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 314 Registered: Aug-06 | well yea i can take pics but its the kenwood 9102d amp and u cant take the front cover off they made it liek that and all u can do is take the back one off and u can only see the back of the chip and i took it off and yes i did smell something weird , and the cover had like a brown streak on it and my guee\ss is it is fried but i can put the pics up if u would liek but the brown streak is hard to see if i showed it on the pic and another thing how do i post pics up i tried and it wont work |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 619 Registered: Dec-06 | press upload image next to the post button. the pic can only be 600x600 it sounds like it is fried take it to a shop |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 315 Registered: Aug-06 | yea but do i like paste the pic in the box rite here where you write messgaes? and yea i aint takeing it to a shop but my dad called bestbuy and they said if the cerial number is on the amp they wil fix it . i dont know if they mean replace teh amp or just fix it thereselfs but i dont hink bestbuy fixes amps do they? |
Bronze Member Username: QuirkySA, Texas Post Number: 55 Registered: Feb-07 | they do. fried my amp n took it there but it was so bad that its not worth fixing. it also helps 2 know if u have the manufacturer's warranty on the amp still. http://www.bestbuy.com/site/olspage.jsp?id=cat12102&type=page&contentId=10433636 03930&entryURLID=cat12085&entryURLType=page&h=287#majorbrands |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 318 Registered: Aug-06 | ok yea . so they wil tel you if it is to bad to fix or what? and what is a manufactors waranty is that the 1 year thing or is it the waranty that u ha to pay for ? |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 320 Registered: Aug-06 | bump |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 321 Registered: Aug-06 | BUMP |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 331 Registered: Aug-06 | B.U.M.P. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2016 Registered: Jan-06 | "take off the cover to the amp. if somethings fired you will be able to see it. if you can take some pics and post them im sure some ppl here can point out some things for ya. also if its fried u will prob be able to smell it" however....if you take the cover off, and they can tell its been taken off, that will usually void your warranty because YOU are not supposed to open the amp |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 332 Registered: Aug-06 | yea i have taken it off and there seems to be a brown streak and yes it did smell a lil bit, but when u take teh cover off its the back one and you cant see the top of the chip where all the stuff is only the back of it but ill tak epics fror the heck of it, and how would they know if i was carefull about takeing it off, and not stripping the screws hwo will they know? |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 333 Registered: Aug-06 | i tried uploading a pic but i think you need a user account of some sirt to do that on a website that u keep pics on so i don tknow how else i can do it |
