Sub hitting weird.
Username: Tanmanfosho
Fi SSD15 Wangers
Post Number: 1033
Most of you know I have a 15inch SSD with a flatwind coil...Well until a few days ok the sub was just fine. Now it hits weird in certain places like it can't get notes it used ot get or something...And also. When im switchign through songs. Like from track 1 to 2 to 3 etc. It makes a weird bumping noise lie ktis bumping but not to a song... idk... any suggestions???
Username: Volfenhagking1600
I WILL be 15 Wangin
Post Number: 334
check ground
Fi SSD15 Wangers
Post Number: 1034
ok bump
Username: Naledge503
Qnited States of FI Ca...
Post Number: 1078
Maybe a bad rca signal?
Fi SSD15 Wangers
Post Number: 1035
ground is fine. ive checked all the wires. except the ones going into the sub cause thier hidden by the box....
Fi SSD15 Wangers
Post Number: 1036
bump
Username: Blazerboy
15 $$D... Wangin? ...T...
Post Number: 409
My old subs used to do that bump when I switch songs or a radio station.
I have my 15" SSD + flat coming soon...interested to know the answer if it comes up with mine.
Username: James1115
Use a simple...
Post Number: 9502
I would say a bad RCA cable also. Get a new set and run them over your seats really fast and see if it stops. If it does there you go:-) if not you try something else. process of elimination.
Username: Tremor1127
Fi Car Audio [:-]
Post Number: 1141
yes, process of elimination.
and check your gain. ("it hits weird in certain places")
Username: 40hz
N.C. Usa
Post Number: 193
AS far as your sub not hitting like it used to,mines doin the same and i cant figure it out.get a test cd or 1 of the bass mekanik cds w/test tones on it.mine hits great from 25 to 32 hz,then its dead from 33 to 43hz.the sub moves alot and i get alot of rattles but no,very little sound,then 44 hz on up its bangin agin.I bet yours is about the same,i dont have an answer yet but thought id letch know youre not alone on this aggrevating issue.
