What the diff sound in size 12", 15" , 18" ?
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 79
i only have had 12"?
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 385
the bigger is more spl but less sq
Post Number: 81
so bigger is better ?
Username: Rustysurfer916
Oviedo, FL
Post Number: 385
the bigger, the louder. and it will rattle your car more on the deep hits. but the smaller the better quality. if you listen to rap and rap only get an 18 or 15. i listen to rap and rock. and to me a 12 is perfect cuz you still get that punchey bass (alot better with a 10 though) and it hits and rattles my car on the really deep notes still. its like having a 15 and a 10.
Username: Nickb4247
Post Number: 249
With a correct install and a well made driver, a 15 or even an 18 can sound very good.
