CD/Satellite Audio for Cadillac
Username: Lilyf
I want to replace the factory cassette player/radio in my 1999 Cadillac Deville for a CD player/satellite ready unit. How do I know what type of unit to buy that will fit in my car? I'll probably get the CD player at Best Buy because you get free installation with the item, but I want to make sure I'm getting something that will work in my car. Thanks for the help.
Username: Sheriff
Post Number: 121
Well, if you're going to get it from Best Buy, they most likely will have it at Circuit City. So go on Circuitcity.com and when you are looking at the HU they will ask you to put in your car make/model/year and then it will tell you if the HU will fit or not.
Username: Lilyf
Thank you Corey, I went to Circuit City.com and got the information I needed!
Dawn
Username: Wolfeyes1987
I have a 1993 Ford Taurus and I'm trying to put a CD player in it, but I have no idea what wires are for what. Can someone please help me?
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1544
Chris Bower!
Click here!
Enjoy!
