Bronze Member Username: LilpimpdPost Number: 49 Registered: Jul-06 | which are easier to wire?? and im getting a kicker 1500.1 zx amp which would fit thos amp perfect?? |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 715 Registered: Aug-04 | Wiring them is going to be the same difficulty no matter which one you choose. |
Silver Member Username: The_image_dynamicSan Diego Post Number: 412 Registered: Dec-06 | Not necessarily because the 3000 has quad coils. Still pretty easy to do though. |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 717 Registered: Aug-04 | Ohh...my bad. Didnt realize that. Will be easy none the less just like hooking up 2 subs then. |
Bronze Member Username: LilpimpdPost Number: 51 Registered: Jul-06 | then how can i wire 2 tc 3000's to a 2500.1 zx amp?????? |
Bronze Member Username: LilpimpdPost Number: 53 Registered: Jul-06 | so how coul di wire them to this amp??? |
Bronze Member Username: RemotiaPost Number: 12 Registered: May-06 | http://www.tcsounds.com/TC_pics/drivers/tc-3000/wire/07.jpg |
