Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 267 Registered: Jan-07 | hey i was wonderin bout the Hifonics XX-Colossus II 3200 rms, http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3461 but it will be on 4 solo-baric l5 12's rated at 600rms a piece which = 2400rms of kicker subs, but 3200rms hifonics amp cause i dont think hifonics will be as true as kicker but 2400-3200 i think will ush em great if not yall let me know another is will that amp get warm? |
Silver Member Username: LoudonPost Number: 825 Registered: Jun-04 | ok heres my take on this ... ull get a good amoount of the rated power with a good electrical to wire the sub to one ohm .. ur subs would have to be dual 4 ohms to wire it down |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 396 Registered: Dec-06 | Why not get L7s? If you're buying ebay the price is not much different and they are a lot better IMO...just wondering. |
Silver Member Username: Skibum12189Cleveland Post Number: 276 Registered: Mar-06 | I've heard that lower end Hifonics amps are overrated (you'll get about 80% rated") but I think that the higher end (colossus, etc) are very good amps. Mike, that amp is 3200 at 2 ohms and I think you can wire 4 dual 2 ohm subs to 2 ohms. And yea, I think you should consider getting L7s with the same amp. |
Bronze Member Username: ImalikJackson, New Jersey Ocean Post Number: 72 Registered: May-06 | That amp is a beast...get the big 3, go with the CVX |
Silver Member Username: Nd4spd18Post Number: 359 Registered: Jul-06 | Even the XX series are overrated, but decent budget amps. They do about 80% of their rated power. |
Bronze Member Username: ImalikJackson, New Jersey Ocean Post Number: 74 Registered: May-06 | where do you get 80% from????thats a bunch of bull..The XX series are far from overrated... |
