Amp for subs
Username: Talon_es93
Trinidad, Co
Post Number: 564
whats a good amp for my 12" CVRs dual 4 ohm... i was thinkin the AW8002V.... any opinions????
Username: 54danny54
KY More Wang Th...
Post Number: 3527
nahh.
go with a phoenix gold xenon 400.1
Trinidad, Co
Post Number: 565
idk thats half the watts for double the price
Trinidad, Co
Post Number: 566
any other opinions
Username: 54danny54
KY More Wang Th...
Post Number: 3536
ohh so u have 2? and u need 800 watts?
or what
Trinidad, Co
Post Number: 567
ya.. sry for not makin it more clear.
Username: Nd4spd18
Post Number: 381
Hifonics 1206d is a good budget amp for those subs.
Username: Logan__tille
Imortal Box Building
Post Number: 6048
That^^^or a orion 1200D or ED NINe.1, something around there
Username: Johnfiac
IL Afghanistan,...
Post Number: 1494
how much are you trying to spend.. new or used or does it matter?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 690
The a8002v is a pretty decent amp for the money. I dont think you will have any problem powering those subs with that amp.
Trinidad, Co
Post Number: 568
about 200 or less... would they get louder on a 800watt amp @ 1 ohms..rather then when i had them hooked up to a 2 ohm stable 1500 watt amp @ 1 ohm... i know i was risking alot but it sounded good.... but i'm scared to blow stuff out so imma get this new amp before anything else happens
Username: Adam_s
Post Number: 692
That audiobahn amp isnt stable at 1 ohm. You could hook each sub up to its own channel at 2 ohms and each sub would be getting 400 watts.
Trinidad, Co
Post Number: 569
sounds good... i might go with that one or the hifonics.. i seen that orion in action but the 800 series and it was bad azz
... but it a lil bit to much $ for this set up...... but hooked up right will it bump louder... its i give it 400 watts on the right amp rather then hookin it up to a 2 ohm stable 1500 watts amp @ 1 ohm
Username: Nd4spd18
Post Number: 440
Someone on this forum was selling a hifonics 1206d for $160, but I forget who.
