Ground
Username: Kickerman
Post Number: 88
can i ground three seperate amps through a distribution block
Username: Adddisorder
West palm, Florida
Post Number: 3293
yes you can is it the best way, thats debatable. id run a separate ground for each amp
Username: Nd4spd18
Post Number: 343
^^^^ x2
Username: Kickerman
Post Number: 90
ok would you run all three grounds to the same place or run them to three separate places
Username: Nd4spd18
Post Number: 346
I have done several installations with multiple amplifiers grounded to the same place and have never had a problem. But I also know people who gorund each amp to a different place. So basically do whatever you want.
Username: Kickerman
Post Number: 91
ok now i have another question not related to the topic above where is the best place to buy a pioneer premier 880pprs for the best price
Username: Kickerman
Post Number: 92
bump
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11503
ebay
Username: Kickerman
Post Number: 93
someone
Username: Kickerman
Post Number: 94
thanks
West palm, Florida
Post Number: 3300
yeah ebay but you get no warrentee if that matters.
