MARSHALL/CANAAN
Username: Darkvirus
Mt. vernon, AR United States
Post Number: 18
The last thread got swarmed by idiocy, having to repost after having 15 replies about bullshit is ...
Anyway, I've read that one of you two people have the formula for calculating a system's efficiency. Could you please post it?
Username: Southernrebel
Post Number: 4440
Yes, I posted a formula awhile back that calculated a systems efficiency (power and SPL used incalculating this).
I have since forgot this formula...but you can search on this forum for it. I believe the thread was titled something like "Wanna know oh efficient your system is?"
I was working on some stuff in physics when i posted that thread...I cant remember all of it now though.
BTW...i am Marshall. I just changed my name on this forum to Canaan while back.
(all my friends now me as Canaan...its was getting confusing w/ me posting as Marshall)
Username: Rvlacos
DD 3512 , VR1000D 15= overcomp...
Post Number: 1729
"The last thread got swarmed by idiocy"
lol
u have to calculate:
var deltaX = x2-x1; var deltaY = y2-y1;
then
convert theta from radians to degrees.
if that doesnt work try this
"Find x > 3 such that
ln(x) < x^(0.1)"
you have to understand the theory of operation:
Q = (P1 - P2) r4 / 8cL
Q = Volumetric Flow Rate
P1 = Static pressure at the inlet
P2 = Static pressure at the outlet
r = Hydraulic Radius of the restriction
c = (eta) absolute viscosity of the fluid
L = Length of the restriction
Since , r and L are constant, the equation can be rewritten as:
Q = K(A P/c)
and then you will have your answer!
