Ot-Install Problem
Username: Greeney1888
Clover Grove, Murderapolis... We from the ...
Post Number: 329
when i try to install my Alpine CDA-9847 HU in my car it sticks out about an inch cause its to long. there is really nothing to move or cut to make more room so am i SOL until i get a new one?
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 1040
There has to be something you can move or cut...did you measure?Get a flash light and see what's back there.Then get a dremel and cut out the area just enough to allow your HU to slide back.
Clover GroveIts the capi...
Post Number: 330
thanks man
Username: Adddisorder
West palm, Florida
Post Number: 3248
some HU have a little like thing that sticks out that back to adjust the length
Username: Rvlacos
DD 3512 , VR1000D 15= overcomp...
Post Number: 1696
"little like thing that sticks out" lol
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1842
real simple...get a circular saw and cut that extra length off of the back of the HU, problem solved...it will fit then...just wont work.
