Alt qustion
Username: Rosrock2000
Notre dame!USA
Post Number: 283
would would a 1200d ma audio amp put out really?
my main question is there any way an "upgraded" alt or even ho alt can do 18 volts??? cause my friend keeps tellin me thats what it said on the cap or meter whatever you call it. I said the best they can do is 14.4 so whos right?
Username: Nd4spd18
Post Number: 301
There are HO alts with external voltage regulators where the voltage can be adjusted. But the electronics in your car can not handle 18 volts.
I have seen dual alt setups where one alt is a standard 14 volt to run the car, and the other is set to 16 volts for the amplifiers.
