Newbie question need help!
Username: Darkale85
Averil park , Ny Renn
Post Number: 260
Hate to do this but i have to know.... is it a big deal to underpower
a sub?now i know this is not very clear because i didnt specify on
what kinda sub or any thing well here goes i want a single 12,or 15
inch sub setup but i would like to try and stay with my jl audio amp
now i was looking at the jl w6's because there really nice looking
subs well the rms on the subs are 400 and the amp is 250 the other sub
i was thinking about and i know this is a very different type of
sub... but is like a 15 inch kicker solo L5 like i said i dono what
the big deal is and i was wondering if i could get away with this if
not no biggy cause i have a secondary amp i can use for more power
just would like not to use it cause i dont want to have a big drain on
my alt. thanks in advance for any help and for takeing the time to
help me out
Username: Stnorris
Davenport, IA US
Post Number: 1992
theres no such thing as underpowering a sub. that doesnt happen.
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 5626
no. under power it all you want. What do you tink its doing when the volume is down low?
Username: Darkale85
Post Number: 262
well i just wanted to make sure cause i didnt want to do any thing bad if at all posible
Nj US
Post Number: 3414
Only thing with underpowering it is you increase your odds of clipping it to death because of trying to push you amp to its' limit. A high powered amp at 25% sounds better than a crappy one at 75%.
Nj US
Post Number: 3415
^^^"Your amp"
Username: Darkale85
Post Number: 263
im sorry what do u mean by your amp? if your asking on what i have i have a jl audio 250/1 and a audio art 100h.c. which does 2 x 50W @ 4 ohms
2 x 235W @ 2 ohms
2 x 550W @ 1 ohm
1 x 1100W @ 1 ohm bridged
but i would prefur not to use it at 1 ohm cause i dont want to upgrade my electrical system yet thanks again
Nj US
Post Number: 3416
I was just proofreading my post. My spelling gets out of hand sometimes. If you push a small amp to its' limit you risk sending clipped signals to your sub, and distortion is any speaker's worst nightmare. So yeah, I guess if you don't set your gains right, you CAN hurt a sub underpowering it.
Username: Darkale85
Post Number: 264
ok but if i set the gains lower and by lower i mean not very high at all it should not be a problem correct?
