Friend help
Username: Thumping_corsica
Mi, Mi Unitd states
Post Number: 305
My friend is planning on getting 2 type r 12's and a 2400d(does 1200 at 1 ohm).. I told him about fi and he said hed like opinions..would a 12 btl be louder than this?
Username: Ars88
P.I.M.P , Pakistani/In...
Post Number: 417
i would def. think so because if u add an extra sub...you would prob get about 4-5 db gain....if you power the btl correct imo you should be able to get louder than a simple r...
but ive been wrong at times and if im wrong right now some1 plz correct me
Username: Adddisorder
West palm, Florida
Post Number: 2954
putting a btl on 1200rms seems stupid
Username: Ars88
Post Number: 418
u gotta feed the btl with atleast 2000 watts rms...anythin under that would be a waiste of a btl...
if u wanna use 1200 watts..then i suggest u go for a Q or a BL....def. not a btl
Mi, Mi Unitd states
Post Number: 307
nono my bad... i mean BL not btl ;)
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 1116
I would still think the more power the better on the BL... It's rated at 1500 and I'm sure it can take more. It would probably still sound nic oen 1200 watts, but that's more of the Q's range. You could look into an SX or 2 12 RE SE's They're on Ebay all the time.
Post Number: 1117
If that's the 2400d directed amp then you wont even see 1200 watts. Probably much closer to 1000.
Mi, Mi Unitd states
Post Number: 309
o really? yeah hes getting a driected 2400 watt.. didnt realize they underate amps..
West palm, Florida
Post Number: 2958
dont know what your talking about reece unless you can back up that statement with some proof.
DEI makes very good amps and are rated accuratly he should see 1200rms from it + or - 50
Username: Nickb4247
Post Number: 122
my wcc5000 (orion2500d) does around 2700rms(depending on voltage.)
Username: Gh0st_31
FL USA
Post Number: 204
reese they are rated 1000 watts not 1500. a fully loaded bl is probly around 1500. the q and bl are rated exactly the same. q is more sq though. and i agree with matt i used to have an old directed 1100d and it performed very well.
