Box for Stroker Pro
Username: Hgihkcin
Lincoln, NE
Post Number: 72
Should i put it in a transmission line or a simple ported box?
Username: Adam_s
Post Number: 473
Do you have the skills to design and build a transmission line?? I would say go w/ a simple ported because of the ease.
Username: Kravenblood
Ohio DD Z1 you wi...
Post Number: 198
ported lol the 12 only needs 1.9447 cu ft. and thats with woofer and port displacement they recommend ported at 25 hz 2 for front and back
12.5" x 16" 2 for sides 21" x 14.5 2for top and bottom 16" x 21" well if that fits in your car 3" port 18.75" long they have on the sheet they sent me
Post Number: 199
here is the sheet cv sent me
text/richtextUpload
stroker pro.rtf (71.6 k)
Username: Hgihkcin
Lincoln, NE
Post Number: 73
is that for the old stroker, cuss on their website it says completely different stuff
Post Number: 201
thats for the new stroker pro thats what they emailed me.. when i was asking about a box i was going to build
Username: Southernrebel
Post Number: 4273
They this:
2cuft NET
12"x2" slot port, 26.5" long
34hz tuning
Post Number: 202
and yes i am porting mine to the recommended 25hz, i am not adjusting the bias...well not yet anyway.. my box is going to be what they recommended besides the port im going a little larger than the 4 inches
