Bronze Member Username: Lt_450rNorth branch, Mich. Lapeer Post Number: 69 Registered: Dec-06 | Are Mtx better than memphis? are they better than the sony xplod you buy at walmart? Need to know thank you!! |
Silver Member Username: OneracistguyTWO EGG, FL USA Post Number: 175 Registered: Sep-06 | almost anything is better than xplodes whats ur budget for subs and what do u want sq sql or spl |
Gold Member Username: CtmikeCt. Post Number: 2965 Registered: Feb-06 | mtx sucks. better than sony but that isn't saying much. |
Silver Member Username: OneracistguyTWO EGG, FL USA Post Number: 178 Registered: Sep-06 | what are u sayin the jackhammmer is the best sub ever built...j/k |
Silver Member Username: Rosrock2000Notre dame!USA Post Number: 179 Registered: Dec-06 | for 400 dollar budget just buy a btl.. look it up at ficaraudio.com. I had an ssd and it looked bad as* never got a chance to listen to it though(stolen) |
Silver Member Username: OneracistguyTWO EGG, FL USA Post Number: 180 Registered: Sep-06 | for 400 there is so many options the he11 with mtx |
Silver Member Username: Lil_jonPost Number: 392 Registered: Jul-05 | all the above named brands will just lead you to buying somthing else in the future |
Gold Member Username: James1115Use a simple... Post Number: 8825 Registered: Dec-04 | where did he say his budget is $400? I never saw that. |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 4844 Registered: Feb-06 | lol i was just wondering that |
Silver Member Username: Trey4sportsPost Number: 329 Registered: Sep-06 | audioque HD3...get one 15 and you wont need anything else |
Gold Member Username: RvlacosDD 3512 United States Post Number: 1355 Registered: Sep-06 | 1 xplode on a xplode 1200 watt amps will xplode in ur trunk! lol imo memphis is better than mtx hands down, i never seen u post a budget of 400 but even if ur budget is 200 u can do better. |
Silver Member Username: Rosrock2000Notre dame!USA Post Number: 186 Registered: Dec-06 | dude.. he posted his budget was 400 dollars for a sub in another thread so lay off! |
Bronze Member Username: Streetridersr22Mason city, Iowa U.S. Post Number: 50 Registered: Dec-06 | go wit mtx 9500 u can get em cheap on ebay and they are loud as hElL wont disappoint ya |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11181 Registered: Jul-05 | ^^^Until i pull up....lol |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3295 Registered: Feb-06 | why buy cr@p when u can get cr@ppier. and not mtx its not better than memphis. |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3296 Registered: Feb-06 | the end. you play too much metal gear solid 3 snake eater right??? u should call your sell the fear or the fury and i forgot the others ones event hat i finished that game around 8 times already |
Gold Member Username: JohnfiacIL Afghanistan,... Post Number: 1088 Registered: Mar-06 | mr rob did u just say mtx is better then memphis? lol |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3300 Registered: Feb-06 | no i said that mtx its not better than memphis |
Gold Member Username: JohnfiacIL Afghanistan,... Post Number: 1092 Registered: Mar-06 | oooo ok... i was gunna say you should know better with 3300posts lmao.... typo had me confused.. "and not mtx its not better than memphis" no mtx is not better than memphis lol |
