ALPINE IVA D300 FM radio tuner problem
Username: Hgroth
Palma
I have a IVA D300 US model and just moved to Europe and I cannot tune into some radio stations that are located on even frequencies, i.e. 95.8Mhz since this model will only scan the odd frequencies. Is there something I can do to change this?
Username: Taruntyagi
Did you find any solution to this problem . I have similar problem with a Pioneer Car MP3 player.
Username: Dkchillin
Vermont
Post Number: 374
On US versions you have to look specifically for "European Tuning" as a feature and a lot of (most) decks, including the IVA-D300, don't have it.
I would imagine the same is true for you Tarun, but I obviously can't say for sure since you didn't indicate what model deck you have.
