Box for DD9915 w\Replacable ports **MARSHALL WHITE**
Username: Johnfiac
IL Afghanistan,...
Post Number: 966
My question is How deep\wide would my ports have to be for these tuning options. All MUST have a port Hieght of 10" (port will be made with 1" Oak.) Im looking for 30hz, 35hz and 40hz. The width of the port hole can be as much as 14" wide.... the picture shows all details... basically this is for replacable ports for different tuning options...Thankz for the idea marshall
Username: Johnfiac
IL Afghanistan,...
Post Number: 969
What is the displacment of the dd9915? anybody know? THat must also be brought into concept along with port displacment as well
Username: Johnfiac
IL Afghanistan,...
Post Number: 989
^bump!
Username: Southernrebel
Post Number: 4016
There is alot of math involved, you would just have to site down and figure out the displacments of the wood.
Kinda hard to explain unless i could sit down w/ ya and draw it out.
VVVVV (this is if you use 3/4" mdf) VVVV
But, to tune that box to 35hz....do a 7"x10" opening port 27" long (it will have to make an L in the box). Make sure the hole in the box will be large enough. The port will displace 1.52cuft, the sub is ~.25cuft. You will have 4.55cuft net.
For 40hz, 7.5"x10" port.....18" long (L port again) 4.95cuft.
Play around w/ this calculator:
http://www.bcae1.com/spboxnew2.htm
you will have to take into account the displacments of the wood the port is made of.
