Sub puts amp in protect mode
Username: Sexybrat
i had my 15" kicker L7 wired for 2 ohm then one day i was cruiseing around for a good hour or so then my amp went into protect mode i narrowed it down to the sub i changed the wiring to 8ohm it worked for a bout 2-3 days then it did the same thing any ideas on wut is going on my amp is a lanzar 1600watt viberant
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1347
Lanzar is the problem
Username: Sexybrat
i have a PYLE PLA2210 coming u think it will better and wut ohm load do i want my sub wired at
Username: Extrmndor3
Sit and Look pretty
Post Number: 3121
its gonna be worse lanzar> pyle/pyramid/boss
Username: Nyyfan13
Fi SSD USA
Post Number: 2025
ouch man. pyle and lanzar. thats a no-no. can you return either of them and get a better amp?
Username: Bumpngrind
Post Number: 12
I feel ya on ur amp going into protection all the time! Mine does the same thing.
Username: Zoomiebird
Gville, FL
Post Number: 244
dudes let me tell you how to do it:
Step 1: spend a month or more without buying another cheap crappy amp
Step 2: make (and save) a little extra dough
Step 3: buy good amp
Result: bass like you've never heard, and that doesn't go into protect
Cheers!
Username: Sexybrat
thanx for the input wut would be a good one to get to power my kicker i want it to pound !!!!
Sit and Look pretty
Post Number: 3134
i think yoru in like a budget find a hifonics brutus that will meet your needs
Username: Sexybrat
i just discovered that my sub seized up. why would it do that and is it toast or is there hope for it??
Username: Sexybrat
yanks man i wish i could :-( wish i knew more when i got it
Username: Nyyfan13
Fi SSD USA
Post Number: 2053
i understand man, it happened to a lot people. before you buy something else, come pay us a visit
Username: Sexybrat
Post Number: 7
well im now in the market for a new sub voice coil burned up i want another kicker i have 2 12" 350watt max performance subs i might have to live with them for a while mabe if one of u has a 15" kicker or another sub for sale il take a look at it thnx guys
Username: Imalik
Jackson, New Jersey Ocean
Post Number: 47
You may like this.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3709
Break them in for a few weeks and you will be happy
Username: Skibum12189
Post Number: 31
Selling My Hifonics Bxi1206D. Great Beginner Amp and could definitely push an L7 or a CVR. Lemme know what you'd wanna spend. It pushes about 900 Hifonics rms which wouldn't overpower a 750 watt cvx or L7. I'd take 150 plus S&H
Post Number: 32
That was 1200 at 1 ohm or 900 at 2 ohms
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 915
umm $150...is like brand new price...lol jk dude
Username: Frkkevin
Post Number: 2436
... this will be a lesson learned for you :-)
save some money and give us your budget and we can help you rebuild with something better
Username: Sexybrat
Post Number: 8
heres the deal guys my budget is about $500-$600 but i have very limited room in my truck i have about 56"lenght 10"bottom 7"top and 16"high behind my seat
Orangevale, Ca. USA
Post Number: 1362
Thats about 4 CF
Orangevale, Ca. USA
Post Number: 1363
If you subtract 3/4" for the walls you are left with 3.1466154 CF. The port and sub displacement needs to be subtracted as well.
Username: Johnfiac
IL Afghanistan,...
Post Number: 929
sq or spl?
Username: Pike110
12w6v2s, Indianapolis...
Post Number: 325
Before you buy anything new. Make sure you know how to set your gains correct. That is a big problem when you are using gear like lanzar, pyle, and pyramid. They say 2000 watts on them, but they don't put out even close to that. So, some people I'm not saying you did, turn the gain up to try to get it louder and end up toasting the subs. Just make sure you do a lot of research on here and ask a lot of questions. The last thing you want to do is buy some decent products and end up burning up the coils on the subs and so forth. Just my 2cents.
Username: Sexybrat
Post Number: 9
is that 4cf enough room? i got a sealed box at those measurements. as for sq or spl wuts that mean? i would like to know more about setting amps and such im kinda new to this and i dont get some of the term and such. thnx for all ur help and input every little bit helps
Orangevale, Ca. USA
Post Number: 1366
56" X 8.5"(average between the 10" bottom and the 7" top) X 16" = 7616 / 1758 = 4.3321956 CF. This is just over 4 cubic feet, but these are not taking in consideration the wall thickness and/or sub and port displacement.
You need to use the 3.1466154 CF measurement. That one has the walls configured for 3/4".
Username: Frkkevin
Post Number: 2535
your measurements are confusing?.. you have two heights? but which is which..
Orangevale, Ca. USA
Post Number: 1367
Its a slanted box Kevin.
The bottom is 10" wide and the top is 7" wide.
To get the exact volume you subtract 7 from 10 (10 - 7 = 3).
Then you divide the difference in two (3 / 2 = 1.5).
Then you add the difference (1.5) to the smallest number (7). So, you add 7 + 1.5 which comes to 8.5 :-)
So then the math comes out.
Username: Sexybrat
Post Number: 10
so i picked me up a L7 kicker for 150bux canadain now is my box gonna be ok for it? and wut kind of amp should i get for it? any input is apprectiated as i said b4 in new to this stuff lol
thnx guys
